1 members (Steelonsteel), 44 guests, and 3 robots.
Topics128,090
Posts1,056,024
Members48,432
#920742 02/18/2013 10:12 AM
Does anyone have pictures or can tell me how to install the emergency brake lever that mounts to the transmission for my 1945 two and half ton Maple Leaf truck with the cables that go to the back drum (stock)? Lost my pictures.
Ralphie
I have a couple of the assembled bottom of the assembly in the middle of my photo bucket. Mine is for 1/2 ton pickup. I think that part is simular.
back yard wrench turner
Ralphie,
Does this work?
E brake
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
That looks about like mine except the cables are tight at the cable adjustment bolts. One thing i discovered was my rear break drum assembly was missing a cross piece between the break shoes -at the top near the wheel cylinder. It is so that as the cable pulls the rear shoe this cross piece pushes the front shoe against the drum. I was able to find the piece. Without this it did not work.
Many thanks. The pictures were a big help.
Wayne-
What proportioning valve did you use? how chosen?
Originally Posted by Tj_M
Wayne-
I used 2, 2lb valves for the front disc brakes. I used 1, 10lb for the rear brakes.
I chose based on cheapest price on ebay.
Wayne
1989 Silverado
Wayne -
What is the brass block that the residual pressure valves are attached to? i thought that was the proportioning valve???
Tj
TJ,
That is the distribution block. I don't have a proportioning valve in my setup.
Wayne
1989 Silverado
