2 members (Rusty Heaps, panic),
51
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | I installed a reproduction turn signal on my 53 chevy and I also installed a EZ wire kit to update the truck to 12 volt. I was not getting any power to the connecter for the flasher relay. so I bypassed it by running a wire from the leaving side of the brake switch and then combined the brake switch wire to the power wire coming from the turn indicator switch. Everything was working perfect until I re routed the wires I believe I have hooked up the wires the same and only one side will flash but the hazard lights will flash but not the left side. I replaced the relay and now the right side will flash but its a hit or miss of it working. Any help would be great. | | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | This is a little hard to follow but I would rethink your logic. It sounds like you are co-mingling a switch circuit (brake) and the relay circuit (flasher). There is a reason they are separate. One, is the brake lights should still function if the flashers are activated. I would be trying to find out why there is no power to the relay in the correct configuration. I would expect any connections made from either device to the lights would be parallel and not in series. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are many styles of "reproduction turn signal" kits. Without knowing the brand/model, it is not really possible to explain all the possible circuits. Here is a very good, general Tech Tip, authored by Cletis. | | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | That is a great Tech Tip, didn't know about it. Nice work Cletis! | | |
