4 members (FAST55, tclederman, Oswald, 1 invisible), 52 guests, and 0 robots.
Topics128,075
Posts1,055,918
Members48,429
#92050 06/08/2005 10:50 PM
Rookie question. After reading Horvath's great posts, I've decided to go EZ Wire for my 47 AD. Since I'm changing to a 292, are there any differences in the wiring, or is it all basically the same in the engine bay? I guess I could ask the folks at EZ Wire, too. Thanks in advance,
jay
Your lack of preparation is not my emergency
#92051 06/10/2005 1:43 AM
I'm pretty sure it's basically all the same, Jay.
The EZ-Wire instructions show how to wire various types of alternators or generators, etc. ... and if anything else comes up, you can always call the EZ-Wire tech guys as well as ask here.
Keep us posted on your progress!
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#92052 06/10/2005 1:53 AM
I was hoping you'd be the one to write back, Horvath. You are a sage. As soon as I get a digital camera(and my front metal put back on), I'll post some pics.
jay
#92053 06/10/2005 1:43 PM
Hey Jay,
I too followed the advice of Horvath, and used the EZ wire harness. I have a 283 small block and it was a pretty smooth job in wiring.
Wiring Harness Pictures
Hope this helps.
Chris
Chris 1955FirstSeries
#92054 06/20/2005 5:42 AM
Junior Member
Junior Member
I just purchased a harness from ez wiring and a light switch. The whole wiring went well except for the light switch wiring. Does anyone out there have wiring diagram that show the pin out of the switch. The lights work and flashers and turn signals work. The turn signals are from Grote and I had to bypass the hazard and flasher to get it to work with the old Flasher/Hazard relay. When I start the 51 the tail and licence plate lights turn on with the light switch on the off position. So I suspect my light switch is not wired correct.
#92055 06/20/2005 11:40 AM
Maybe THIS will help?
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#92056 06/22/2005 2:01 AM
Anonymous
Unregistered
Anonymous
Unregistered
What does this harness consist of? On my 53 its just a fire waiting to happen and I dont want all my hard work to burn down. Does it replace every wire on the truck? Does it make a difference of you have an alternator or a generator? If you go to an alternator later what can you or do you have to do? Did you wire them yourselves? Was it realatively easy? Did you buy the kit right off the site (or where?)? Which kit did you guys buy?
Thanks soo much!!!
BTW, I read your site chris and your truck looks awesome!
#92057 06/22/2005 3:24 AM
Quote
Every single wire on the truck gets replaced, bro.
Check out my install Here
Quote
It doesn't matter as far as the kit is concerned ... but if you're going to go with an alternator, I would do that when I do the wiring kit and be done with it; do it right the first time out.
Quote
Did it all myself. Yup. And it was fun! It looks daunting when you get the kit -- but plan each wire before you start ... know what you are going to do before you do it ... then take one wire at a time and it's easy as pie.
Quote
Those questions are answered at my site (link above) with a link to the kit I bought.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#92058 06/22/2005 11:46 PM
Anonymous
Unregistered
Anonymous
Unregistered
Thanks Alan! That answers alot of my questions. Just one more, I do not have any power anything, its all stock. Should I still go with the kit you got, or should I go with the EZ 12. Will I have way to many wires laying around if I go for the EZ 21 like you did? Like I said, I have the straight six, stock guages and such, just in the process of working out my 12V. Someday it will be updated somewhat. Thanks again.
#92059 06/23/2005 12:17 AM
If the EZ 12 is gonna handle all your needs, now and in the future, then certainly go for it. No sense in having a dozen circuits you'll never use ... but if the EZ 12 is questionable; if you think you may one day run short, or perhaps a future owner may want more, then I'd say go with the EZ 21.
Simple as that, bro'.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#92060 06/23/2005 1:24 AM
Anonymous
Unregistered
Anonymous
Unregistered
okay well then I guess I will have to decide. The price isn't all that different between the two, I like to keep my options open though. I guess I will just have to decide. Thanks again.
#92061 06/23/2005 1:59 AM
If the price isn't that much different, go with EZ-21 ... just coil up the wires you aren't going to use, tuck 'em up under the dash, neatly, and pull the fuses on those circuits. Then whever you want to add something, you've got the wire and it's own circuit.
Plus, if you ever sell the vehicle, having all that will help in the selling features.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#92062 06/23/2005 3:36 AM
Anonymous
Unregistered
Anonymous
Unregistered
Sounds good. I will give them a call one of these days and get on it. Thanks
#92063 06/24/2005 11:16 PM
Alan,
Get back and play your guitar. You're spending way too much time on the bolt. Hope all is well with you. This post remined me that I have a complete harness replacement in my garage somewhere buried. Maybe when I'm done restoring the daughter's '65 Mustang, I'll search for it and rewire my daily driver.
Craig
Craig
