2 members (Buckeye998, J Lucas),
301
Mod | | | Forums66 Topics128,152 Posts1,057,012 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 60 | I have sprayed down the square nuts over and over, but they are just too rusted. I am thinking of just taking a grinding tool and cutting them off. I just want to know if that will mess up putting them back on (running boards(, or if they are bolts that can replace. Thanks | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | I have a 46. If they are like mine they are carriage bolts. They slide into a channel in the running board. Easy to replace when you get it all apart. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Many people simply break those flat-headed carriage bolts (or, cut the bolts). Several vendors sell replacement-bolt sets (I think some bolt-sets are stainless steel). Classic Parts calls them Step Bolts | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | I've been splitting the bolts with a grinder till the nut is cut in half then they come off easy with no damage to running board.
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | I didnt even bother trying to save the old rusted,,crudded bolts. Just twist them til they snap and get some new 1/4-20 carriage bolts for replacement, from your local ACE Hardware. Then you can save the cuss words for another project............ | | | | | Joined: Nov 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 60 | OK, I'm cutting them off, Thanks | | |
