1 members (Wooley), 105 guests, and 0 robots.
Topics128,151
Posts1,056,997
Members48,460
I have sprayed down the square nuts over and over, but they are just too rusted. I am thinking of just taking a grinding tool and cutting them off. I just want to know if that will mess up putting them back on (running boards(, or if they are bolts that can replace. Thanks
I have a 46. If they are like mine they are carriage bolts. They slide into a channel in the running board. Easy to replace when you get it all apart.
Many people simply break those flat-headed carriage bolts (or, cut the bolts).
Several vendors sell replacement-bolt sets (I think some bolt-sets are stainless steel).
Classic Parts calls them Step Bolts
I've been splitting the bolts with a grinder till the nut is cut in half then they come off easy with no damage to running board.
1937 Chevy 1/2 ton panel
I didnt even bother trying to save the old rusted,,crudded bolts. Just twist them til they snap and get some new 1/4-20 carriage bolts for replacement, from your local ACE Hardware.
Then you can save the cuss words for another project............
OK, I'm cutting them off, Thanks
