4 members (55shaker, classicfins, Charles in CA, CandoBrent), 113 guests, and 3 robots.
Topics128,128
Posts1,056,664
Members48,450
#920228 02/16/2013 8:49 AM
I am rebuilding my heater assembly and am not sure if it has ever been upgraded to 12v. This heater has two motors, one for the cab and one for defrost. I tested both and they work but did not run them long since I was testing with 12v. Question:
1) Is there any way to tell if it is a 6 or 12 volt motor.
2) If six volt, can I just install a voltage reducer for these.
3) This heater has a Chevrolet metal decal on it with a rectangular core, no fresh air. Would this be original to a "48" cab. Name on back plate is Harrison HO-147.
If you never tell a lie, you never need to remember what you said.
I don't think those heaters with 2 motors were made into the 12V years, pretty safe bet it has 6V motors unless the truck has had a spendy conversion to 12V .... most of the small motors have voltage imprinted on them, otherwise if you can round up a 6V battery or a charger with dual voltage function you should be able to tell, a 12V motor would have a hard time starting on 6V and turn way slow
yes, you could use a pair of reducers, if there's room to mount them so they safely dissipate the heat
Would I be better off just changing them to 12 volt over using two voltage reducers. Mounting the reducer under the dash is not a problem, I just want to avoid future problems.
I would like to see a picture of this 2-motor heater.
Is this a two-motor heaters? I think so (1947 De Luxe Heater and Defroster).
It would have also been available in 1948 (part-year, or, maybe all-year).
yes Tim, "separate electric switches" is the key, my 46 GMC had one that looked different than that one, but had the dual paddle switch unit that someone has posted a picture of in the past
yes Bart, changing to 12V motors would be preferable to using reducers, which get very hot and add one more failure possibility
Or, you could avoid using any dropping resistors all together and wire the two in series
dropping 6v across each one. Of course you wouldn't have the choice of running each one
separately any more.
Since the truck has apparently been altered from it’s original design, i.e., converted to
12v, it shouldn’t make any difference to you if you use a single switch for the
heater/defroster.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
The heater shown by tclederman is the one I have. Denny, thanks for that advice. I think I will bench test these motors wired in series and see how that works before I spend $120 on two new motors. At this point I am not sure how much it will even get used in cold weather. I need to check on the year of this cab since it is not the original cab. I have the plate that came on it that I should be able to tell for sure if it is a "47" or "48".
I dont know if this is possible but if you ohm the motor out providing its good, can you tell the voltage by a formula? I guess if you knew how many poles it has. I know you can do that on a/c motors. Not sure about d/c.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
I believe that this would be a good choice to operate and protect your 6v heater motors and switches on 12v ...
> CLICK - Ron Francis Voltage Reducer
- Lonnie
My '54 3104
