10 members (Samantha, Bill Hanlon, 55shaker, 1955 1 Series, cmayna, Otto Skorzeny, Stelonlevo, JW51, treegrower, 1 invisible),
133
Mod | | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Trying to figure out horn wiring, read alot of posts with good info. But here goes; should I have continuity between the mast bearing and where the wire comes out of the steering column? Trying to determine which components need replacing. 1953 3100 with 1956 car 235, has horn relay on firewall. Thanks, Paul | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | You should have continuity between the Mast bearing, to the Wire that comes out at the bottom of the mast. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And on thru to the horn relay also. When the Horn button is pushed it shorts the contact ring on the mast jacket bearing to ground completing the circuit to the relay. The relay operates completing a circuit to the horn.
Denny G
Denny G Sandwich, IL
| | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Thanks Denny and Dads 50. Should the horn contact ring have continuity through it only when depressed? Are those little insulating washers (some missing/deteriorated) behind the rivets holding it together? Is there supposed to be some other insulation material in there? Is that repairable? Maybe time to buy all new. Thanks, Paul | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here is a pic of a replacement mast bearing ..link... You should have continuity from the metal ring on top to the end of the wire. If you dont then the wire is broken in the mast. Here is a replacement retainer if yours is bad ...link...
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Be sure that the top of that mast bearing is clean. Mine was tarnished and didn't work, a light steel wool brushing got it going again. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Gus has ya on the right track Paul. Sounds like your horn button retainer that he's linked you to is shot. The two sides of that are indeed insulated from each other and should only make contact when you put pressure on the upper one and they touch. Denny G
| | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Ordered mast bearing, contact plate and spring/insulator assembly. Want to mount trumpet style horn(not correct, but I have one) onto 1956 235 manifold without mounting tabs. Any ideas? thanks again all. | | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | So, new mast bearing, new contact plate, provided 12v to horn relay and relay closes when button depressed. Hot wired horn and horn works. Hook up horn to relay and nothing. Does horn (trumpet style) need to be bolted down to complete circuit? Have 1956 235 w/o bracket on manifold. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd say yes Paul - if you're using a relay, then the column horn button gives a ground to the relay, letting it pass the power to the horn [+], then the horn would need a ground for the power to flow
Bill | | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | Since we are on the science of horns... mine is grounded somewhere and blows by itself when the relay is connected. Ring and spring contact is removed, still blows. I have taken apart the relay to see if it is stuck and it appears to operate properly in testing.
Is there a spot that is a common grounding problem I can look for? '59 TF | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Dave - check the wire from the steering mast bearing down the column to under the dash, might have some bad insulation that's shorted - I think you'll find a connector that can be unplugged just under the edge of the dash - use an ohmeter to check from there to the relay as well
Bill | | | | | Joined: Dec 2012 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2012 Posts: 97 | Thanks Bill. Good advice, I didn't know where to start. Chasing electrical ghosts can be no fun. Dave | | |
