7 members (66flea, Gray_Ghost, Charles in CA, Wally / Montana, dt235sd, Christian, 1 invisible),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i need some help,can anybody tell me how do you get the harmonic balancer off the front of a 55 chevy 235,there are no bolts on the front, only what looks like 5 rivets and a hole in the middle, any help would be greatly appreciated...thanx
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are two threaded holes on the face of the balancer. A puller like this should pull it off. This style puller might be available on loan or for rent at an auto parts store. | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | I used a normal stearing wheel puller.
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | so, there are no bolts to take it off? what holds it on?
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It's a press fit, friction.
| | | | | Joined: May 2012 Posts: 35 New Guy | | New Guy Joined: May 2012 Posts: 35 | Anyone know off hand what the thread pitch of the two threaded holes is? | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I have done it with a steering wheel puller. The first time i used a hand ratchet then got smart the second time bought an air rachet much easier. I was surprised its just a press on fit.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | The steering wheel puller i bought at autozone had two bolt sizes the corse thread eas the one i used not the fine thread. I just do not remember which size it was.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | And not too long! Don't want to damage the timing cover (only once and it way a very long time ago!).
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Feb 2000 Posts: 5,202 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,202 | It's also a press fit going back on. The outer ring of the balancer is held on to the inner ring with a rubber type material. If you pound really hard on the inner hub driving it back on, you can separate the two pieces destroying the balancer. GM used a special holding tool that held both pieces as one.
To help installing, you can heat the balancer to 200 degrees with out worry and if possible cool the crank using dry ice or set the engine outside in the cold. When you have everything ready, hammer, brass punch, gloves, etc..... in one quick motion, align the key way and shove it on, then quickly tap the center hub to seat the balancer to the timing gear and crank shoulder. If all goes right, you should be able to get it 75% or more on the first stab. Be sure to clean the two surfaces really well and remove any burs or rust.
A second option is to drill and tap the center of the crank and use a small block Chevrolet bolt and washer to pull it on and hold it there. Any machine should be able to drill the crank or you can do it yourself with a hand drill and sharp bits. The crank is fairly soft and drills quit easy. Being dead center is not required but you should try to be as close as possible.
Joe | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Joe, 235 balancers do not have an outer ring like small block Chevs and others that can be damaged while assembly. The rubber is behind a plate that is held in place with 6 rivets. The risk is damaging the thrust bearing only.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i got the harmonic balance off today, i used a gear puller and an air gun, and zipped it right off, thanks for the help everyone!!!! | | |
