| | | Forums66 Topics128,054 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | I am going to have to break down and replace the old bias tires (they are square) and wheels on my '72 C60. I am thinking to replace with radial tires (ie 285/75R 24.5)and aluminum wheels. What is the best tire on the market for the money with emphasis on good ride characteristics. And should the front end alignment be changed going from bias to radial tires? Toyo, Bridgestone, Michelin come to mind as possible choices but I need some good feedback. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Not sure why you would want to go with a tire that big. I think you will find clearance issues with them. What bolt pattern and hub type does your truck have? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I agree about tires that big. Unless this is working semi tractor or wrecker it seems terribly big to me. Original tires on a C60 were likely 8:25 x 20. And why such major name brands ($$) unless it is a working vehicle. I've run a lot of so/so brands with good success for the occassional useage. But as always it's your truck and your money. Just curious. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Does your truck have 10 hole stud piloted wheels? Otherwise you will probably have to get custom wheels made. They are not going to ride good because you need to keep 100 psi in them. These are what we call lopro 24.5. I run lowpro 22.5. I buy a lot of tires from this guy. http://www.worldoftires.com//index.php?cPath=43_45If you have Michelin or Bridgestone in mind, add about $200 per tire. | | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | Thanks for the replies. My truck indeed has 10 hole stud pilot wheels. The reason for the tall tires is to try to get some more mph for highway speeds. The current tire on the front measures about 41 inches tall and if my calculations are correct a 285/75R 24.5 is 41.3 inches tall. The tires on the rear currently are a mixed mash with the shortest one about 38 inches tall. Why I am on this subject can anyone also give some input to aluminum wheels. One additional item will the lugs have to be changed out for length when changing from steel wheels to aluminum. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | If you have room, an 11R24.5 will give you even more speed. You will need longer studs. If you go to a Euclid distributor, they can probably fix you up. Euclid is a brake and suspension part distribution network owned by Meritor. In the trucking industry we find it much easier and accurate to use revolutions per mile to calculate road speed. Here is the calculator I use. http://www.roadranger.com/ecm/groups/public/@pub/@eaton/@roadranger/documents/content/ct_062746.swf
For some reason it will not post as a link, but I think it will copy and paste. If not, Google Roadranger speed calculator. | | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | Good input, thanks. I would still like some input on aluminum wheels ( 10 lug stud pilot) Who's got the best for the price, Alcoa, Accuride others? | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Stud piloted are almost a thing of the past and its not the manufacturer but the dealer who makes the deal. California is about the only place that still has interest in stud piloted 24.5 wheels. I sold 8 really nice 8.25 x 24.5 to a guy in CA not long ago for $75 each. He figured he got a real bargain, and I was glad to get rid of them because no one wants them and I was about to run them across scales for the aluminum. Salvage dealers are glad to get rid of them too. However salvage dealers charge all the market will bear. If you appear anxious to get them, you will be quoted a fat price. | | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | after reading crenwelges post I have to ask does anyone know a source for used 24.5 aluminum wheels. I live in the Nashville Tn area. | | |
