| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Is the stock bolt pattern on a mustang II front end 5x4.5 ? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You can get the rotors in almost any bolt pattern you want. I think my buddy got his from speedway for the GM car pattern. Haven't checked but you probably can even get 6 lug truck. | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | Yes , i know i was wondering what the original bolt pattern was. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Most of them were 4 lugs, only the V8 mustangs had five. They are 4 1/2" though | | | | | Joined: May 2011 Posts: 266 Shop Shark | | Shop Shark Joined: May 2011 Posts: 266 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | All Mustang 2s are 4 bolt stock. Only the aftermarket kits use 5 lug, most of them allow you to specify either the Ford/MoPar 5x4.5 or the GM 5x4.75 pattern.
Bill Burmeister | | |
