2 members (2 invisible),
84
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, I have an after market door on the passenger side. I would like to mount the stock style mirror. Can I drill the 3 holes and JB Weld nuts on the inside of the door for the bolts? Should work right?
Thanks!
Jon
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | should work, just hafta be careful about positioning so the arm sits on the curve right - but if you still have the old original door it'll have the plate inside it for the mirror mounting location even if it never had one
Bill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi Bill, Yes cool thats what I thought I will just need to be very careful on the drilling...Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Place the mirror and gasket on until correct, hold the gasket there and mark it. You should be able to use regular nuts held from the inside with a wrench. I did that. with bigish washers of course.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | I started out with black mirror mounts...but just do not think it looks good...going to go to chrome...was mounting the outside door handle today and chipped a nice big half dollar size chip of paint...great fun 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I started out with black mirror mounts...but just do not think it looks good...going to go to chrome...was mounting the outside door handle today and chipped a nice big half dollar size chip of paint...great fun Always a good idea when drilling on painted surfaces to cover the work area with painters tape,the blue or green tape and mark and drill through that.
Drew
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Jon, if you go with nuts on the inside of the door you may want to consider nylock self locking nuts to prevent loosening from vibration. On the chrome mirror brackets, as well as a lot of other items, beware of poor quality plating on a lot of the repops out there.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Thank you Bruce. I got the mirrors from Classicparts.com 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Keep an eye on them for awhile. It's been suggested here before that if the threads or any other area begins to show rust, get it removed and brush with clear nail polish. Worth a try. The repops I used on the 59 rusted slightly but the big rust producer was the chrome tail light brackets I used. I was getting ready to toss them for the black painted before I sold the truck.
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | I will have both now. I am a bit worried living in San Fran...The weather up here has no mercy on vehicles...but the truck is in a garage. So that I hope will slow down any rust...
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | Unless it's a garage with humidity control. The 59 was always garaged and stayed dry except for washes and the occasional caught in the rain drive. Would be nice if they'd repop these in stainless.
| | | | | Joined: May 2010 Posts: 89 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 89 | Have you thought about nutserts? Floyd
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
| | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | My 58 Suburban came with a drivers side mirror. It has a support bracket on the inside of the door with welded on nuts. There is nothing on the passenger side. Has anyone seen a source for these brackets? I imagine the sheet metal alone isn't strong enough for the stress of the mirror since they are reinforced on the drivers side. What do you think. My Burb is in amazing shape and I'd hate to ruin a perfectly good door by putting a crease in it around the mirror arm.
Larry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the reinforcer with nuts should have been there even without the mirror, if it's missing you'll need to scrounge one used, or fab something similar yourself, don't do without
Bill | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Bill;
I was afraid of that. I guess I'll have to learn how to fabricate parts.
Larry
| | | | | Joined: Oct 2006 Posts: 76 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 76 | I just bolted mine on and have had no problems. That curve at the mirror location makes it pretty strong and that mirror don't weigh hardly anything. But, placeing a piece of sheet metal inside should be an easy task also. | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | How thick of a piece of sheet metal should I use? I was thinking I'd have to bend up a piece of 1/4" plate and get the holes drilled in the right alignment. Might be a lot easier than that.
Larry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | look at the driver side, it doesn't have to be that thick, some heavy scrap sheet metal will do .... use the mirror arm to mark hole position on the door, then mark the reinforcer thru those holes
Bill | | |
