1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#91854 05/02/2003 5:00 PM
Is there any place the rebuilds core guages to handle 12V or is it easier to add a reducer?
#91855 05/02/2003 7:01 PM
It's much easier to add a reducer, the only one that needs it is the fuel gauge. Then, just change the light bulbs to 12v ones.
Paint & Body Shop moderator
#91856 05/02/2003 7:58 PM
really? I was figuring more than the fuel guage, your right, reducer is much easier if its just fuel guage
#91857 05/02/2003 9:12 PM
Parts needed for 12v conversion:
1. Resistor for fuel gauge (+) terminal.
2. Ballast resistor between ignition and coil.
3. 12v coil.
4. 12v alternator/generator.
5. 12v bulbs/fuses.
6. 12v headlamps
You may also want to get a 12v heater switch and blower motor, as the variable resistor will likely melt even with a voltage reducer on the circuit.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#91858 05/03/2003 2:03 AM
Z
Z Offline
what i did is bought a twelve volt battery with a six volt tap from www.antiqueautobattery.com .i bought two fuse panels from a boating store,so i have a twelve volt fuse panel and a six volt fuse panel.
#91859 05/03/2003 8:00 AM
Of course, if you're converting a '54-'55.1 GMC to 12 volt, you can always just dig up a set of native 12 volt gauges from the '55-'59 GMCs. I have two sets, the last one, from eBay, cost a whopping $15, including shipping. The only different things are a generator warning light rather than an ammeter and the electric temperature gauge.
1954 GMC De Luxe COE
#91860 05/06/2003 1:27 AM
Don't forget about the radio, Jim Carter sells a voltage reducer that they say is good enough for a radio Reducer
BiggerHammer
"The key is in knowing where to hit it"
