0 members (), 91 guests, and 4 robots.
Topics128,024
Posts1,055,393
Members48,422
#918498 02/09/2013 5:00 AM
Can anyone telll me which way up should the two u shaped rails be on the rear of my 51 chassis should be please. And fixed to the underside or upper side . currently as per pic.
http://i1327.photobucket.com/albums/u667/riomar3/chevypics3010_zps64c54757.jpg
wc54 #918521 02/09/2013 7:46 AM
ODSS Lawman
ODSS Lawman
Welcome wc54!
Using my '51 as referrence, those rails in your photo are actually part of the bed. Here is a photo of mine when I refinished my BEDWOOD
They are flipped in orientation from your picture and go where they are in my link above. The third one is at the front of the bed under the front bed panel. You can see the carriage bolts that fastens them to the frame along the top of the frame near the bed sides. In the stock orientation, these bolts should actually go through the bedwood with an off center washer. The previous owner installed them this way and I like that it hides the bolts under the bedwood so I left it like that.
There should be many smaller holes along the solid part of the support that the bolts for your bedstrips will use.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
wc54 #918568 02/09/2013 11:41 AM
wc54 might be talking about the spare carrier cross channels?? Not the bed cross channels. They are mounted the same in both pics.
wc54 #918625 02/09/2013 3:12 PM
ODSS Lawman
ODSS Lawman
OOpps!!!
Sorry wc54, MNSmith is correct. The tire carrier braces are correct per your photo...
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
