2 members (Bill Hanlon, TPR57C),
63
Mod | | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | Which carburetor should go with 1948-1950 216 engine?
I bought a chassis with engine/tranny and rear diff as a project, but the carburetor was missing. I see "Rochester" and "Carter" carbs online but wonder if they both would fit or if one is better, etc. The truck was a 1950, but the engine i.d. says that it was for a 1948 Chevrolet passenger car. | | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | Thank you! Appreciate your research from the manuals.
I see carbs for $45 from scrap yards and $300 on Ebay for rebuilt ones. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | As I recall the '49 Carter W-1 carbs were a one year model. Some years ago I needed one rebuilt and the kit was a special order item that was more costly than the other models.
I recently had the carb rebuilt for the '46, it was a model 616-S Carter W-1 carb and the cost was $150.
Hope that info helps. | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | With enough research, you'll find (on this site and elsewhere) that common experience is the Carter W-1 is somewhat cheaper to buy and rebuild, and are generally considered to be bullet-proof. Carter refined this carb through the years, with the final version starting in 1941 - I think it's the 483s - addressing the last few minor issues with the W-1. The Rochester -as from the factory - gave a few more horsepower, but are widely known for being leaking, messy monsters. I think Carbking has said that he used to routinely have to put them in a jig to re-flatten the flanges. Other than the mess, I haven't heard that they're unreliable. I think the kits for them are reasonable as well. And they're plenty of them out there - they often show up on the earlier trucks as replacements for the Carters. Here's carb king's page for the W-1s. Carter W-1 Hope this helps? -Michael | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have a carter YF787s on my 50 216 manifold on a 235. I have no complaints. Good luck Here is some info on the Carter's from carbking I did an abbreviated list of these once before. This is a complete list taken one by one from the Carter master prints, and includes experimental carbs with numbers assigned, but no production.
THERE ARE DIFFERENCES IN THESE CARBURETORS! THAT IS WHY THERE ARE DIFFERENT NUMBERS!
Some of you have already experienced some of these differences such as the "ported" vs "manifold" vacuum take-off for the distibutor.
Use the list as is, and I would guess few issues. However, changing from one application to another may lead to issues.
At any rate, here is the list:
Jon.
Carter YF carburetors produced for use on Chevrolet
756s – 216 engine aftermarket 1937~1952 787s – 216 engine aftermarket 1937~1952 788s – 235 engine aftermarket 1950~1952 789s – 235 engine aftermarket 1950~1952 890s – 235 engine aftermarket manual choke (number assigned, no production) 891s – 235 engine aftermarket auto choke (number assigned, no production) 964s – 216 engine aftermarket manual choke 1937~1952 965s – 216 engine aftermarket auto choke 1937~1952 966s – 235 engine aftermarket auto choke 1950~1952 967s – 235 engine aftermarket manual choke 1950~1952 2008s – 216 engine aftermarket 1937~1952 2046s – 206 engine aftermarket 1932~1936 2100s – 235 engine aftermarket manual choke 1953~1956 2101s – 235 engine aftermarket auto choke 1953~1956 2104s – 261 engine aftermarket (number assigned, no production) 3055s – aftermarket (number assigned, no production) 3211s – 235 engine aftermarket 1957~1962 3379s – 153 engine original equipment manual trans 1962~1966 3402s – 153 engine original equipment auto trans 1962~1966 3711s – 194 engine aftermarket 1962 3760s – 230 engine (number assigned, no production) 3770s – 230 engine (taxi) original equipment auto transmission 1964~1965 3771s – 230 engine (taxi) original equipment manual trans 1964~1965 3772s – 194 engine auto transmission (number assigned, no production) 1964 3773s – 194 engine manual trans (number assigned, no production) 1964 3821s – 194 engine (van) original equipment 1964 3946s – 194 engine aftermarket 1964~1965 3946s – 230 engine aftermarket 1964~1965 3975s – 230 engine (van) original equipment manual trans 1965 3976s – 230 engine (van) original equipment auto trans 1965 4043s – 194 engine (van) original equipment manual trans 1966 4043s – 230 engine (van) original equipment manual trans 1966 4044s – 194 engine (van) original equipment auto trans 1966 4044s – 230 engine (van) original equipment auto trans 1966 4048s – 230 engine (van) aftermarket experimental 1963~1966 4072s – 194 engine original equipment auto trans CALIF smog 1966 4072s – 230 engine original equipment auto trans CALIF smog 1966 4073s – 194 engine original equipment manual trans CALIF smog 1966 4073s – 230 engine original equipment manual trans CALIF smog 1966 4080s – 194 engine original equipment (pass) auto trans CALIF smog 1966 4080s – 230 engine original equipment (pass) auto trans CALIF smog 1966 4080s – 250 engine original equipment (pass) auto trans CALIF smog 1966 4085s – 230 engine original equipment (truck) manual trans CALIF smog 1966 4085s – 250 engine original equipment (truck) manual trans CALIF smog 1966 4086s – 230 engine original equipment (truck) auto trans CALIF smog 1966 4086s – 250 engine original equipment (truck) auto trans CALIF smog 1966 4145s – 194 engine original equipment (truck) manual trans 1965~1966 4145s – 230 engine original equipment (truck) manual trans 1965~1966 4202s – 250 engine (taxi) original equipment auto trans 1966 4203s – 250 engine (taxi) original equipment manual trans 1966 4278s – (export to India) 4339s – 194 engine aftermarket 1963~1967 4339s – 230 engine aftermarket 1963~1967 4339s – 250 engine aftermarket 1963~1967 4367s – 230 engine original equipment manual trans CALIF smog 1967 4367s – 250 engine original equipment manual trans CALIF smog 1967 4368s – 194 engine original equipment auto trans CALIF smog 1967 4368s – 230 engine original equipment auto trans CALIF smog 1967 4368s – 250 engine original equipment auto trans CALIF smog 1967 4369s – 230 engine original equipment (truck) manual trans CALIF smog 1967 4369s – 250 engine original equipment (truck) manual trans CALIF smog 1967 4370s – 230 engine original equipment (truck) auto trans CALIF smog 1967 4370s – 250 engine original equipment (truck) auto trans CALIF smog 1967 4371s – 230 engine original equipment (truck) manual trans CALIF smog 1967 4371s – 250 engine original equipment (truck) manual trans CALIF smog 1967 4371s – 292 engine original equipment (truck) manual trans CALIF smog 1967 4372s – 250 engine original equipment (truck) auto trans CALIF smog 1967 4373s – 153 engine aftermarket manual trans 1963~1967 4374s – 153 engine aftermarket auto trans 1963~1967 4375s – 230 engine original equipment (truck) manual trans 1967 4375s – 250 engine original equipment (truck) manual trans 1967 4376s – 230 engine original equipment (truck) auto trans 1967 4376s – 250 engine original equipment (truck) auto trans 1967 4377s – 250 engine original equipment (taxi) manual trans CALIF smog 1967 4378s – 250 engine original equipment (taxi) auto trans CALIF smog 1967 4387s – 194 engine original equipment (truck) manual trans CALIF smog 1967 4480s – 230 engine aftermarket (all Federal) 1963~1967 4480s – 250 engine aftermarket (all Federal) 1963~1967 4492s – 194 engine aftermarket 1962 6213s – number assigned no production | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I have a carter YF787s on my 50 216 manifold on a 235. I have no complaints. Good luck Here is some info on the Carter's from carbking I did an abbreviated list of these once before. This is a complete list taken one by one from the Carter master prints, and includes experimental carbs with numbers assigned, but no production.
Jon.
756s – 216 engine aftermarket 1937~1952 787s – 216 engine aftermarket 1937~1952 788s – 235 engine aftermarket 1950~1952 789s – 235 engine aftermarket 1950~1952 890s – 235 engine aftermarket manual choke (number assigned, no production) 891s – 235 engine aftermarket auto choke (number assigned, no production) 964s – 216 engine aftermarket manual choke 1937~1952 965s – 216 engine aftermarket auto choke 1937~1952 966s – 235 engine aftermarket auto choke 1950~1952 967s – 235 engine aftermarket manual choke 1950~1952 2008s – 216 engine aftermarket 1937~1952 2046s – 206 engine aftermarket 1932~1936 2100s – 235 engine aftermarket manual choke 1953~1956 2101s – 235 engine aftermarket auto choke 1953~1956 2104s – 261 engine aftermarket (number assigned, no production) 3055s – aftermarket (number assigned, no production) 3211s – 235 engine aftermarket 1957~1962 3379s – 153 engine original equipment manual trans 1962~1966 3402s – 153 engine original equipment auto trans 1962~1966 3711s – 194 engine aftermarket 1962 3760s – 230 engine (number assigned, no production) 3770s – 230 engine (taxi) original equipment auto transmission 1964~1965 3771s – 230 engine (taxi) original equipment manual trans 1964~1965 3772s – 194 engine auto transmission (number assigned, no production) 1964 3773s – 194 engine manual trans (number assigned, no production) 1964 3821s – 194 engine (van) original equipment 1964 3946s – 194 engine aftermarket 1964~1965 3946s – 230 engine aftermarket 1964~1965 3975s – 230 engine (van) original equipment manual trans 1965 3976s – 230 engine (van) original equipment auto trans 1965 4043s – 194 engine (van) original equipment manual trans 1966 4043s – 230 engine (van) original equipment manual trans 1966 4044s – 194 engine (van) original equipment auto trans 1966 4044s – 230 engine (van) original equipment auto trans 1966 4048s – 230 engine (van) aftermarket experimental 1963~1966 4072s – 194 engine original equipment auto trans CALIF smog 1966 4072s – 230 engine original equipment auto trans CALIF smog 1966 4073s – 194 engine original equipment manual trans CALIF smog 1966 4073s – 230 engine original equipment manual trans CALIF smog 1966 4080s – 194 engine original equipment (pass) auto trans CALIF smog 1966 4080s – 230 engine original equipment (pass) auto trans CALIF smog 1966 4080s – 250 engine original equipment (pass) auto trans CALIF smog 1966 4085s – 230 engine original equipment (truck) manual trans CALIF smog 1966 4085s – 250 engine original equipment (truck) manual trans CALIF smog 1966 4086s – 230 engine original equipment (truck) auto trans CALIF smog 1966 4086s – 250 engine original equipment (truck) auto trans CALIF smog 1966 4145s – 194 engine original equipment (truck) manual trans 1965~1966 4145s – 230 engine original equipment (truck) manual trans 1965~1966 4202s – 250 engine (taxi) original equipment auto trans 1966 4203s – 250 engine (taxi) original equipment manual trans 1966 4278s – (export to India) 4339s – 194 engine aftermarket 1963~1967 4339s – 230 engine aftermarket 1963~1967 4339s – 250 engine aftermarket 1963~1967 4367s – 230 engine original equipment manual trans CALIF smog 1967 4367s – 250 engine original equipment manual trans CALIF smog 1967 4368s – 194 engine original equipment auto trans CALIF smog 1967 4368s – 230 engine original equipment auto trans CALIF smog 1967 4368s – 250 engine original equipment auto trans CALIF smog 1967 4369s – 230 engine original equipment (truck) manual trans CALIF smog 1967 4369s – 250 engine original equipment (truck) manual trans CALIF smog 1967 4370s – 230 engine original equipment (truck) auto trans CALIF smog 1967 4370s – 250 engine original equipment (truck) auto trans CALIF smog 1967 4371s – 230 engine original equipment (truck) manual trans CALIF smog 1967 4371s – 250 engine original equipment (truck) manual trans CALIF smog 1967 4371s – 292 engine original equipment (truck) manual trans CALIF smog 1967 4372s – 250 engine original equipment (truck) auto trans CALIF smog 1967 4373s – 153 engine aftermarket manual trans 1963~1967 4374s – 153 engine aftermarket auto trans 1963~1967 4375s – 230 engine original equipment (truck) manual trans 1967 4375s – 250 engine original equipment (truck) manual trans 1967 4376s – 230 engine original equipment (truck) auto trans 1967 4376s – 250 engine original equipment (truck) auto trans 1967 4377s – 250 engine original equipment (taxi) manual trans CALIF smog 1967 4378s – 250 engine original equipment (taxi) auto trans CALIF smog 1967 4387s – 194 engine original equipment (truck) manual trans CALIF smog 1967 4480s – 230 engine aftermarket (all Federal) 1963~1967 4480s – 250 engine aftermarket (all Federal) 1963~1967 4492s – 194 engine aftermarket 1962 6213s – number assigned no production | | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | Excellent! Thank you for this info! | | |
