2 members (wilbur53, rfs56trk), 73 guests, and 4 robots.
Topics128,264
Posts1,058,357
Members48,485
#667221 08/03/2010 12:17 AM
U
U Offline
Hi all,
I have an after market door on the passenger side. I would like to mount the stock style mirror. Can I drill the 3 holes and JB Weld nuts on the inside of the door for the bolts?
Should work right?
Thanks!
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
should work, just hafta be careful about positioning so the arm sits on the curve right - but if you still have the old original door it'll have the plate inside it for the mirror mounting location even if it never had one
U
U Offline
Hi Bill,
Yes cool thats what I thought I will just need to be very careful on the drilling...Jon
More pix
Sir Searchalot
Sir Searchalot
Place the mirror and gasket on until correct, hold the gasket there and mark it. You should be able to use regular nuts held from the inside with a wrench. I did that. with bigish washers of course.
U
U Offline
I started out with black mirror mounts...but just do not think it looks good...going to go to chrome...was mounting the outside door handle today and chipped a nice big half dollar size chip of paint...great fun
More pix
Always a good idea when drilling on painted surfaces to cover the work area with painters tape,the blue or green tape and mark and drill through that.
Drew
Jon, if you go with nuts on the inside of the door you may want to consider nylock self locking nuts to prevent loosening from vibration. On the chrome mirror brackets, as well as a lot of other items, beware of poor quality plating on a lot of the repops out there.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
U
U Offline
Thank you Bruce.
I got the mirrors from Classicparts.com
More pix
Keep an eye on them for awhile. It's been suggested here before that if the threads or any other area begins to show rust, get it removed and brush with clear nail polish. Worth a try. The repops I used on the 59 rusted slightly but the big rust producer was the chrome tail light brackets I used. I was getting ready to toss them for the black painted before I sold the truck.
Bruce
U
U Offline
I will have both now.
I am a bit worried living in San Fran...The weather up here has no mercy on vehicles...but the truck is in a garage. So that I hope will slow down any rust...
Jon
More pix
Unless it's a garage with humidity control. The 59 was always garaged and stayed dry except for washes and the occasional caught in the rain drive. Would be nice if they'd repop these in stainless.
Bruce
Have you thought about nutserts? Floyd
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
My 58 Suburban came with a drivers side mirror. It has a support bracket on the inside of the door with welded on nuts. There is nothing on the passenger side. Has anyone seen a source for these brackets? I imagine the sheet metal alone isn't strong enough for the stress of the mirror since they are reinforced on the drivers side. What do you think. My Burb is in amazing shape and I'd hate to ruin a perfectly good door by putting a crease in it around the mirror arm.
Larry
the reinforcer with nuts should have been there even without the mirror, if it's missing you'll need to scrounge one used, or fab something similar yourself, don't do without
Bill;
I was afraid of that. I guess I'll have to learn how to fabricate parts.
Larry
I just bolted mine on and have had no problems. That curve at the mirror location makes it pretty strong and that mirror don't weigh hardly anything. But, placeing a piece of sheet metal inside should be an easy task also.
How thick of a piece of sheet metal should I use? I was thinking I'd have to bend up a piece of 1/4" plate and get the holes drilled in the right alignment. Might be a lot easier than that.
Larry
look at the driver side, it doesn't have to be that thick, some heavy scrap sheet metal will do .... use the mirror arm to mark hole position on the door, then mark the reinforcer thru those holes
