3 members (Bill Marlow, tclederman, 52Carl), 54 guests, and 3 robots.
Topics128,090
Posts1,056,028
Members48,432
Hi folks. I am replacing my drag link on my 52 CDN built 1300 1/2 ton and found out the balls on the Pitman arm and the steering arm look pretty bad.They look like they are factory riveted or slightly flanged out to hold them in.Do you grind the slight flange off and then drift them out? Also what is the best way to refasten them?
Yes - you might need to use a hydraulic press.
Is this what you are looking to replace Jeff?
http://www.pbase.com/dennygraham/image/121615912
Here it is drilled out. When the ball stem is peened over it forms a head like a rivet
because the arm is chamfered. After drilling most of the center out I then used a large
chamfering tool to remove the head, being careful not to get into the arm:
http://www.pbase.com/dennygraham/image/121615915/large
From here you can drive the ball out with a large drift pin.
The replacement ball is threaded and I used a large flat washer to span the chamfer
in the arm.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Someone here on Stovebolt suggested this trick I found helpful when I had this task awhile back. They said to use a center punch and drill into the ball stud about 1/2 inch before using a drift. That was after grinding the swagged end flush first.
There used to be two kinds of replacement balls. One had threads on the end of the shaft and the other didn't. I used the treaded type.
1951 1 Ton Completed
Thank you everyone who posted. They are now removed and ready for the new stuff.Cheers
