8 members (Maybellene, tclederman, RoadsScholar, DadsFirstPickup, baldeagle, MickeyP, Stovebolt48, 1 invisible), 198 guests, and 4 robots.
Topics128,108
Posts1,056,231
Members48,436
#916988 02/03/2013 6:06 PM
I have a 1950 Chevy 3100 that I am wanting to convert from huck style brakes to Bendex style. Is there any company that sells a complete kit to do this? I will be needing everything backing plate, wheel cylinder, hardware, and drum.
I believe the answer to your question would be no. Most people that do this use a doner.
1951 1 Ton Completed
The rear is not so easy unless you change the axle housing.
My Blog
I used the hubs and drums from a 51 chevy belair and they fit right on the factory truck spindles for my 46 1/2ton and I used an s-10 rear, so now I have all bendix brakes and 5 lug suspension
