| | | Forums66 Topics128,106 Posts1,056,217 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 4 New Guy | | New Guy Joined: Feb 2013 Posts: 4 | I have a 1950 Chevy 3100 that I am wanting to convert from huck style brakes to Bendex style. Is there any company that sells a complete kit to do this? I will be needing everything backing plate, wheel cylinder, hardware, and drum. Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe the answer to your question would be no. Most people that do this use a doner. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The rear is not so easy unless you change the axle housing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I used the hubs and drums from a 51 chevy belair and they fit right on the factory truck spindles for my 46 1/2ton and I used an s-10 rear, so now I have all bendix brakes and 5 lug suspension | | |
