2 members (Hotrod Lincoln, mo2cyl), 380 guests, and 5 robots.
Topics128,158
Posts1,057,025
Members48,460
#917440 02/05/2013 2:18 PM
Is there a gasket that goes between the carb and the black plastic piece under the carb (sorry, don't know the name?)
Here is a pic:
Carb Pic
-Troy
Yes.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
That's an insulator Troy, acts as a thermal break between
the carb base and the intake manifold.
Denny G
Denny G
Sandwich, IL
FWIW - neither my '54 Assembly Manual nor my '54 Shop Manual shows a gasket on either side of the insulator. I have an original Bakelite insulator on my '54 235 w/Rochester B and I don't use any gaskets. No leaks.
I tried using a gasket on each side of the insulator but it raised the carb up enough to make the carb linkage too short. The throttle wouldn't open completely.
My Bakelite insulator has a soft coating on both sides (maybe old gas). It seals it at the carb base and at the manifold. Reproduction plastic insulators probably don't seal as well - even if you lapped the two surfaces of the insulator. Note: Chevs of the 40s advertises a "Bakelite" insulator, but it's really just plastic like all the other reproductions.
- Lonnie
My '54 3104
Lonnie,
You are, of course, correct about no gaskets being mentioned in the Shop Manual.
In the purist's tradition, I have tried it with no gaskets. Usually, I have had leaks between the carb and the insulator, so I now always use a gasket there. Most of the time I get away with no gasket between the bottom of a smooth insulator and the top of a smooth intake manifold.
Just in case someone reading this does not know, there are notches in the gasket, one of which should line up with a vacuum hole/port in the base of the carburetor - this notch must line up with that hole in the base of the carburetor.
The original phenolic spacers/insulators had notches in them. Some replacement insulators do not have the notches in them - a correctly orientated gasket must be used with this type of reproduction insulator.
