0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 45 | I am in the process of installing a Mustang II front end on my truck and I would like to know if anyone has use a PS2 power steering pump on their truck? I just do not know if there is enought room to put the pump on the front of the motor. I can change to manual, but I would like for my wife to drive the truck also and she would need power steering. Picture would be great. Thanks Jerry
My first prewar and it will not be my last. Done with the 40 for my best friend. Got a 46 (year I was born) to build for me.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I've got an M2 in my '40 - pretty similar size engine bays I think. I'm running a SBC ( 327 ) with Saginaw pump on standard brackets. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Check in the Speedway Motors catalog part #'s 910-32912 or 910-32913. This is a pump and bracket that is very small. The pump is the same as all but has a remote mount reservoir which is what takes up the room with most pumps. My 34 has a Toyota MR2 electric p/s pump which takes up NO room since it's where the battery box was.
Evan
| | | | | Joined: Jan 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 45 | Thanks for the info. I have been looking for a truck that has a power rack to look at and I cannot find one, but this helps. Jerry
| | | | | Joined: Sep 2004 Posts: 45 New Guy | | New Guy Joined: Sep 2004 Posts: 45 | I had the saginaw P/S pump on the 350 engine in my '38 with Alan Grove brackets , it also had a short water pump . It was a little snugg but not as tight as a newer car , it all depends on how far forward or back and how high or low in the frame your engine is mounted . So many variables but it is possible . Good luck ! | | |
