5 members (55shaker, Nick in Manitou, MickeyP, baldeagle, 1 invisible), 324 guests, and 2 robots.
Topics128,100
Posts1,056,178
Members48,436
#917194 02/04/2013 2:34 PM
I have two very nice air cleaners for my 52 with 235. I would like to know where i can find the mesh filters for these air cleaners?
Thanks, Paul
Ex Hall Monitor
Ex Hall Monitor
Thats it I LOVE YOU MAN!! smile thanks
Paul
I can give you a cheaper and just as good a way if you have the mesh surrounds. I went to the local dollar store and bought copper pot scrubbers (yep $1 each) split them and layered it in. Cleans just like the original with a rinse in solvent and looks like it should.
http://www.flickr.com/photos/advance-design_parts_co/8129206782/in/set-72157631867396207
I will check this out! thanks
Paul,
Take a look at this post.
Harold
http://forums.aaca.org/f169/question-about-air-filter-323187.html Look at post #24 and the photo's.
Harold
Yep that is what I did and the ones I bought were like the tubes described.
Copper mesh? Real oil bath air cleaners uses horse and hog hair! Well, at least mine does (5 of them, to be exact).
We're not talking about "Oil bath" air filters on this thread
farber. We're discussing the Advance Design Chevy truck spark
arrestor and the "real" ones had caged copper mesh in them that
was saturated with heavy oil to catch the dust as it went thru
the copper mesh.
Some of the sealed "oil bath" units that didn't come apart were
stuffed with Sisal, which was also used in the spring cover mat
under the seat upholstery and sisal was used under the rubber
floor mats. I've never been able to find a source for loose
sisal in bulk. I have found 2" thick rubberized sisal batting
which was colored a god orful blue. Another material that was
used back in the day as stuffing or matting was coconut fiber
which looked very similar to sisal. Under a microscope you can
distinguish the difference between the natural plant fibers and
animal hair.
Denny Graham
Somewhere north of Sandwich, IL
Denny G
Sandwich, IL
