| | | Forums66 Topics128,090 Posts1,056,018 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | My 63 C10 is a nice driver but no show truck. I planned to make some body repairs and have painted next winter. Part of that was to include new oak in the box. The wood in there now is peeling and my plan was to remove, sand and refinish to get me through this year. The problem is that one board is split in the rail groove. It's almost separated from the board. Has anyone tried repairing a board? Epoxy and clamp. Maybe I should go with a wood kit now instead of waiting. The other part of my question -What should be used to stain and waterproof the boards. Thanks, OldsCool | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | For the split I will let others chime in for everything you want to know about bed wood and stains go here. www.mar-k.com/ | | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | Hey Brad, Thanks- that link was very helpful ; It does deal with split boards too. I think I'll grab some marine epoxy and give it a go. Worse case I end up with some high test fire wood; -OldsCool | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | For the split, any good quality, waterproof wood glue should do the trick for the short term. Make sure the surfaces are clean and dry, and clamp the joint together for a day or so to allow a good bond. | | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | unlike wood glue, with epoxy you should not apply too much clamp pressure. Sometimes we use duct tape in the shop to hold to parts in position while the epoxy sets-up - about 6 hours.
....David
| | | | | Joined: Aug 2012 Posts: 11 New Guy | | New Guy Joined: Aug 2012 Posts: 11 | Thanks gents, I'll grab some epoxy and hope for the best. I did price new oak. My closest places (southern Ontario, Can) are Bills Trucks, and Antique Chevrolet Parts. Bills (Oshawa) is the cheapest at $550. -OldsCool | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Go on eBay and type in Chevrolet Bed Wood you will find sets for 1/2 that. I bought my oak from a guy down south. Cut and milled for strips it came to $260 with shipping. It was cheaper than buying the raw boards locally and trying to cut it myself. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Olds Cool.....you can make your own boards. Use a table saw or router to cut the grooves along the edges. I was able to hand select boards at my local finishing wood supply - less than $ 150 all in. | | |
