3 members (Nick in Manitou, Wally / Montana, 1 invisible), 58 guests, and 3 robots.
Topics128,076
Posts1,055,920
Members48,429
#9167 03/22/2005 7:40 PM
Junior Member
Junior Member
Hi truck fans. I've got a '66 C-10, and I want to drop the front end 3" with dropped springs and shocks.
I like how the back sits, though, so I won't drop the back.
Is there any danger to the U-joint if I drop the front and not the back?
Thanks!
---MB
1966 Chevy C-10 Fleetside Shortbed
Time flies like an arrow,
But fruit flies like a banana.
There is no danger to the universal joint. However, the rest of the motoring public is at risk from having to share the road with a truck that's deadly dangerous due to handling problems.
Junior Member
Junior Member
You think a rake is dangerous?
I know the drum-brakes-all-around is dangerous, but I don't have the cash for a disc-brake upgrade yet.
---Scoob
stick with the droped spindles thay hurt nothing but try to avoid droped springs thay can realy mess up safe handling
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
You can drop your truck !
Check out Early Classic Enterprises. They have springs that are shorter, however they still have the original spring rate.
You can safely drop the truck with 2" shorter than original springs. I have had them on my 71 for nearly 3 years now with no problems. I use it everyday for my daily driver to work and parts chaser on the weekends.
If you want to drop 3" then you can go with a 1" shorter than original spring and also use a dropped spindle.
CLICK HERE - CHECK THESE GUYS OUT
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
best method is still the dropped spindles.You can get them for about a 2 1/2 inch drop.
Junior Member
Junior Member
Thanks guys. I will eventually use dropped spindles, but I don't want to do that until I can upgrade the brakes to discs in the front. Right now I don't have the $ for that whole package.
I just want to drop the front so it'll stop looking like a "farm truck," and I think I can do that in an afternoon with the drop-springs and shocks.
---Scoob
