| | | Forums66 Topics128,077 Posts1,055,928 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 12 New Guy | | New Guy Joined: Nov 2012 Posts: 12 | | | | | | Joined: Nov 2012 Posts: 12 New Guy | | New Guy Joined: Nov 2012 Posts: 12 | LMC lists a 12 bolt 8 7/8" for those years with anything from a 3.08 to a 4.11. If you cant figure out what it is you can open it up and count the teeth on the ring gear then divide it by the number on the pinion gear. The resulting number is your gear ratio. | | |
