3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#916985 02/03/2013 6:02 PM
msg
Offline
Trying to ID the axle, and I have only been able to find that it has 12 bolts and has this on the bottom right side...
E178 or the 8 maybe a 6, hard to tell
here are some pics
http://i387.photobucket.com/albums/...up/More%2066%20pics/axle_zps8ccb2614.jpg
http://i387.photobucket.com/albums/...066%20pics/numbercloseup_zps108a1818.jpg
Can anyone help me figure this out?
What truck is it under?
msg
Offline
It is a 66 Chevy c10 fleetside, however between the cab and bed the frame has weld marks that appear to have modified. I may have a cab from 66 and a bed from a 64. Not sure.
Here are some more pics
http://i387.photobucket.com/albums/oo320/msgdesign/1966%20Chevy%20Pickup/pic-2.jpg
http://i387.photobucket.com/albums/oo320/msgdesign/1966%20Chevy%20Pickup/DSC_0023.jpg
LMC lists a 12 bolt 8 7/8" for those years with anything from a 3.08 to a 4.11. If you cant figure out what it is you can open it up and count the teeth on the ring gear then divide it by the number on the pinion gear. The resulting number is your gear ratio.
