0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
I will be attempting shortly to replace my worn out upper bearing in my 1950 chevy steering column. My stearing wheel is already remove and I have the replacement kit on hand. I have never attempted this before and leary of damaging the column. Can someone guide me throught the steps? Some say I need a puller to remove the bearing others say it's not necessary. Thanks
look at your replacement - the flange on it fits against the top end of the column tube - all you need to do is use a flat screwdriver or stiff putty knife to gently tap up on that flange to get the old one out, then hand press the new one in - piece a cake
thanks, with you info it was a lot easier than I thought it would be
