7 members (2-Ton, 55shaker, cmayna, Hotrod Lincoln, CuzzFuzz, jmoore, Bill Hanlon),
49
Mod | | | Forums66 Topics128,018 Posts1,055,259 Members48,417 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Is there a source for the red two speed button for the electric switches, I've looked thru Eaton and noting pops up on a search. | | | | | Joined: Dec 2002 Posts: 2,548 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,548 | There are a few 2 speed axle switches with knobs on ebay. | | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | MY 57 GMC 370 has a small lever in the gear shift knob. Was this the original 2 speed axel switch? But it also has the red button clamped to the shift lever with a heater hose clamp.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Jan 2008 Posts: 4,959 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,959 | There are always aftermarket import shift switches on eBay, but they are Asian imports of poor quality. Ever so often NOS switches appear. It doesn't make any difference if they are in a Ford, International or GM box. They are all the same. | | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | Got mine from NAPA. They only have the switch, not the wiring harness connector. I don't remember the part number but wrote it down I think. It was an import I'm sure Scott
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | I bought the switch and harness from my local BIG truck parts store a few years ago...they had it on the shelf. The switch was about $10, don't remember the harness cost. Mike B  | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | I was thinking just the button itself not the complete switch, but that cheap I'll see Napa, I hadn't thought about them in this case. Thankyou | | |
