1 members (Southerntruck),
148
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 35 | will a carb from a 43 216 fit a 54 235 both single barrel | | | | | Joined: Dec 2008 Posts: 87 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 87 | I bought a carter that was used on a 216 for my 235 the bolt spacing was wrong.
1938 Chevy 1/2 ton Pickup 1940 Chevy 3/4 KD Pickup 1946 Chevy 3/4 ton pickup 1940 Chevy 1/2 KC Pickup 1939 Chevy 1.5 Truck
| | | | | Joined: Nov 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 35 | im not sure what model i have off of my 216 the 235 doesnt have one on it right now i didnt know if bolt pattern was same if it would still work or not if jets were differnt or anything like that | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | will a carb from a 43 216 fit a 54 235 both single barrel If it is an original 216 manifold/carburetor: no, the 216 carburetor's bolt-spacing is narrower than on the later 235. I guess you could get it to "physically" work/attach by enlarging the mounting holes in the carburetor's base. The standard 216 carburetor will not allow your 235 to run optimally. Maybe someone else will discuss jetting and flow-volume? | | | | | Joined: Nov 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 35 | any where sell a carb nos or anything like that fairly cheap? | | | | | Joined: Feb 2000 Posts: 5,205 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,205 | Lots of sellers, fairly cheap, NO. Check e-bay for rebuildable cores or you local craigslist. Some of the venders sell core carbs as well as rebuilt ones.
Joe | | |
