7 members (52Carl, Wayne67vert, 53 green 1- ton, Otto Skorzeny, 78buckshot, DadsFirstPickup, greenie-reddy), 67 guests, and 3 robots.
Topics128,130
Posts1,056,713
Members48,454
#916623 02/02/2013 9:09 AM
will a carb from a 43 216 fit a 54 235 both single barrel
I bought a carter that was used on a 216 for my 235 the bolt spacing was wrong.
1938 Chevy 1/2 ton Pickup
1940 Chevy 3/4 KD Pickup
1946 Chevy 3/4 ton pickup
1940 Chevy 1/2 KC Pickup
1939 Chevy 1.5 Truck
im not sure what model i have off of my 216 the 235 doesnt have one on it right now i didnt know if bolt pattern was same if it would still work or not if jets were differnt or anything like that
If it is an original 216 manifold/carburetor: no, the 216 carburetor's bolt-spacing is narrower than on the later 235. I guess you could get it to "physically" work/attach by enlarging the mounting holes in the carburetor's base.
The standard 216 carburetor will not allow your 235 to run optimally. Maybe someone else will discuss jetting and flow-volume?
any where sell a carb nos or anything like that fairly cheap?
Lots of sellers, fairly cheap, NO. Check e-bay for rebuildable cores or you local craigslist. Some of the venders sell core carbs as well as rebuilt ones.
Joe
