4 members (3800GUY, NJC, fonz8261, MNSmith), 156 guests, and 4 robots.
Topics128,095
Posts1,056,468
Members48,443
#91613 03/07/2004 7:19 PM
Does anyone know what the original heater switch for the 1954 Fresh Air Heater looked like and know where these can be found? From some information, it seems to me that it might have a black body with a white toggle which says "AIR", as opposed to "HEAT". The switch for the recirc and fresh air heaters may have been different. Any information from someone who knows would be much appreciated.
Chris - not sure on factory original, but heater switches are normally variable [rheostat] not toggles - this is what our sponser offers:
[img]http://www.americanclassic.com/images/EL118.GIF[/img]
difference in recirc and "fresh air" heaters is a cable control for opening a vent for outside air
Chris,
The 1954 Chevrolet Accessories Installation Manual" shows a toggle-style switch for the Air Flow (Fresh Air) Truck Heater. The manual has no picture/drawing showing the word on the switch. The switch that I have for an Air Flow heater has "Heater" on it.
Tim
The toggle switch functions as a three-position rheostat (off, low, high). There is an old style resistor coil on the back, along with a fuse. The coil has three leads - one at each end, and one in the middle.
1954 GMC De Luxe COE
Chris,
I have those Delco switches (new) if that is what you want. Black body with white toggle that has air on it.
