2 members (Peggy M, Gray_Ghost),
184
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,116 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#91613 03/07/2004 7:19 PM | Joined: Feb 2000 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 41 | Does anyone know what the original heater switch for the 1954 Fresh Air Heater looked like and know where these can be found? From some information, it seems to me that it might have a black body with a white toggle which says "AIR", as opposed to "HEAT". The switch for the recirc and fresh air heaters may have been different. Any information from someone who knows would be much appreciated. | | |
#91614 03/07/2004 8:35 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Chris - not sure on factory original, but heater switches are normally variable [rheostat] not toggles - this is what our sponser offers: [img] http://www.americanclassic.com/images/EL118.GIF[/img] difference in recirc and "fresh air" heaters is a cable control for opening a vent for outside air Bill | | |
#91615 03/07/2004 9:18 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Chris,
The 1954 Chevrolet Accessories Installation Manual" shows a toggle-style switch for the Air Flow (Fresh Air) Truck Heater. The manual has no picture/drawing showing the word on the switch. The switch that I have for an Air Flow heater has "Heater" on it.
Tim | | |
#91616 03/08/2004 12:41 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The toggle switch functions as a three-position rheostat (off, low, high). There is an old style resistor coil on the back, along with a fuse. The coil has three leads - one at each end, and one in the middle. | | |
#91617 03/11/2004 12:32 AM | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | Chris, I have those Delco switches (new) if that is what you want. Black body with white toggle that has air on it. | | |
