2 members (Peggy M, panic), 89 guests, and 4 robots.
Topics128,030
Posts1,055,428
Members48,422
#91610 08/07/2002 2:59 AM
i bought a generic replacement horn for my 48 gmc and proceeded to install it. knowing nothing of what i was doing, it was all trial and error. i found that the horn worked no matter which way i hooked up the two horn wires to the horn. cool with me! so does it matter which wires go to which terminal on the horn? also the old horn had a relay, do i need one? how about an inline fuse? its working without either. thanks!
1948 GMC 250 Series Flatbed
#91611 08/07/2002 3:35 AM
the reason for the horn relay is to run the full power from battery to horn without having it go thru the steering column - safer and allows for lighter wires in the column, where their only function is to energize the relay. as for the pos/neg, should be ground to ground and hot to horn [thru relay].
or whatever works! grin
#91612 08/07/2002 11:07 AM
The horn body should be ground and the prong for the slip on connector is positive.
