1 members (Steelonsteel), 125 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
Ok, next up is Identification of a Clutch and Flywheel Assembly for the 1930 Chevrolet Universal AD - Canopy Express Truck Project
Here are some pictures of what I have on Hand:
Clutch-Flywheel Pict 01
Clutch-Flywheel Pict 02
Clutch-Flywheel Pict 03
Clutch-Flywheel Pict 04
Clutch-Flywheel Pict 05
Looking in my 1929-1930 Master parts list looks like I should have Flywheel Part No: 836363 and the one I have is Part No 836218 (see Pictures Above). If I recall Correctly there two (2) were different size clutches ??
Do I need to find Flywheel and Clutch Assembly Part No 836363 & Mating Parts ?? or will the 836218 Work, and what should I know and do for it to work. From My Research Looks like the 836363 is the correct part and applicable, was 836218 a replacement for the original ?? or ?? Seems liek from the Part No that it was an Earlier Version, or was it a Version just for the 1/2 Ton Pick up ??
What year does Part No 836218 Work on, or moreso what Year was it introduced/ Released ?? It does not show up in my 1929-1930 Master Parts List nor my 1929-1932 Master Parts List I have on hand.
Any insight and Help would be Greatly Appreciated. When I ge home tonight I am going to see if I can gather Part Numbers from the other Driveline COmponents Directly related to the Flywheel & Clutch Assembly. Anyone with Pictures of HOW the Assembly goes together, with what goes where would be GREATLY Appreciated. I have the Master Parts List & the Maintenance Guide, but looking for Actual Photos !!
1929 Chevrolet AC International - 4 Door
1930 Chevrolet AD Universal - Canopy Express Truck
Love the Antique Chevrolet's from 1928-1932
The Beauty, Simplicity, History, and the Stories they Tell
[/font]
- - In the Stovebolt Gallery
-- In the Gallery Forum
3B Offline
Hy BearsFan315, You should not assume that a number that you find cast into a part is the part number of that part. In my experience the part number is not the same as the casting number most of the time, hope that helps.
Thanks... I figure as much, considering the industry I am in we CAST in the CASTING Part Number yet make several Finished/ Machined Parts from a single Casting.
Just trying to make sure I have the right part for my 1930
[/font]
