9 members (48jim1ton, Gdads51, Forty9, Hotrod Lincoln, gswbbc, frogfarmer, Wayne67vert, sron48, dt235sd), 75 guests, and 0 robots.
Topics128,043
Posts1,055,540
Members48,425
#915621 01/29/2013 1:34 PM
My 1960 1/2 ton short bed was a 3 on the tree from the factory. Now it has a sm420 4 speed on the floor. What is the correct drive shaft for this truck?
Thanks !
DiGeM #915635 01/29/2013 3:01 PM
one that fits wink are you missing the shaft altogether? are you looking for length or a part number?
Flxible #915638 01/29/2013 3:20 PM
I'm sorry to be a bother! My question; Is a one piece shaft stock on a 1960 1/2 ton 4 speed?
Thanks again
DiGeM #915779 01/29/2013 9:50 PM
OK I had a '60 with a SM420 trans and it had a two piece shaft with a carrier bearing just infrom of the x in the center of the frame.
Oh and BTW if you look on the shop manual, youwill not find anything on the drive shaft! Look under propeller shaft!
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
DiGeM #915790 01/29/2013 10:23 PM
RJ Offline
it is a one piece D-shft with a slider yoke on the front for the shortbed with a 4 speed trans,i do have them used in stock.
[email protected] for more info.
