| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 19 | My 1960 1/2 ton short bed was a 3 on the tree from the factory. Now it has a sm420 4 speed on the floor. What is the correct drive shaft for this truck? Thanks ! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | one that fits  are you missing the shaft altogether? are you looking for length or a part number? Bill | | | | | Joined: Mar 2009 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 19 | I'm sorry to be a bother! My question; Is a one piece shaft stock on a 1960 1/2 ton 4 speed? Thanks again | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | OK I had a '60 with a SM420 trans and it had a two piece shaft with a carrier bearing just infrom of the x in the center of the frame.
Oh and BTW if you look on the shop manual, youwill not find anything on the drive shaft! Look under propeller shaft!
| | | | | Joined: Mar 2005 Posts: 189 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 189 | it is a one piece D-shft with a slider yoke on the front for the shortbed with a 4 speed trans,i do have them used in stock. [email protected] for more info.
