5 members (Charles in CA, TexasA&M48Truck, BC59, Danielbolt, Otto Skorzeny), 98 guests, and 2 robots.
Topics128,094
Posts1,056,483
Members48,444
#91566 12/02/2003 5:31 AM
on a 52 gmc which terminal is + and which is -. the gauge has 50- / 50+ on the face.
thank you
#91567 12/02/2003 3:26 PM
Bondo Artiste
Bondo Artiste
Very good question........
My truck has the regular gauge, reading "D" or "C" for the battery. I guess someone has switched it out before I had the truck.
I look forward to someone's response, I have thougt about switching the gauge out for the other type.......
~ Phillip
#91568 12/03/2003 10:18 PM
Not sure, but I remember reinstalling mine when I redid the wiring harness. Think I got it in with the wires backwards and when I started the truck up, it read that it was discharging. Swapped the wires and then it read that it was charging. Believer that the ammeter simply reads the amps inline with the wires and you can't screw it up beyond reading incorrectly. Good luck!
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#91569 12/03/2003 11:42 PM
Geezer is right. Hooking the ammeter up backwards does it no harm, just reads the wrong way. If a "+" or "-" isn't indicated at the terminals, then hook up and if it reads in the wrong direction then simply reverse the connections.
