| | | Forums66 Topics128,076 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | Does anyone know a good machine shop in Houston that can resurface my flywheel? I am putting in a new clutch and would like to get this done since I have it all apart.
Also, would any parts store have a replacement clutch and throw out bearing?
1950 Chevy 3600
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | NAPA thinks they have it. NCF 1104123 for 9 1/8" clutch NCF 1104003 for 10" clutch
regards, Leon | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Just call a repair shop or transmission shop that does major repair work in your area and ask them where they take their stuff for machining. If the flywheel is not burnt or warped and teeth are Ok, it's OK. Try to determine the newest year flywheel that will fit that will give you a better chance to find one new. The PN's given by Leon are $130 or $150. The price INCLUDES throw out bearing, pilot bushing and installation tool.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 |
1950 Chevy 3600
| | | | | Joined: Jul 2012 Posts: 163 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 163 | My clutch is the 10 and 3/4 nine bolt. Any one have any idea. The part number above we're wrong sadly.
1950 Chevy 3600
