1 members (Sjm), 149 guests, and 5 robots.
Topics128,266
Posts1,058,385
Members48,485
#915304 01/28/2013 10:25 AM
I would appreciate any advice.
The 235 that we transplanted into the '51 GMC just ate it's second starter (foot pedal activated).
The engine itself runs well, and I was just lowering the idle when it gave a terrible noise and we shut it off.
It seems to me that the starter is not fully disengaging from the flywheel after starting the engine, so when the engine revs it "over revs" the starter. Make sense?
Is this a starter, engine, or installation issue? BTW, neither starter was new or rebuilt, so they could have just been old & worn.
I'll be buying a rebuilt/new one today.
Thanks - Dickson
1950 Chevy 3100 short bed
1951 GMC 3/4 ton long bed
Do you have the correct retracting spring on the linkage?
My Blog
No, I'm not. Where should I look for that?
I'll take a look.
ARRGGH...I don't think I have one...That makes perfect sense. I'm engaging the starter, but without a spring to disengage it the engine is over-revving it...
$150 starter, ruined by lacking a $2 spring!
Good to know. Thanks! smile
Better start doin' your homework Dickson.
Nice clear picture Gus, explains everything.
Denny G
Denny G
Sandwich, IL
You're right Denny. I'm new to old trucks with foot starters, so I'm doing my homework "on the job." smile
Also, I had a guy helping me do this engine transplant. I had hoped he'd catch this sort of lapse! Thanks.
Well don't be shy, these guys here are loaded with knowledge
about these old trucks and there's always someone to point you
in the right direction. Might save you from having to buy three
starters next time.
Denny G
Denny G
Sandwich, IL
I was wondering if it was a 6/12 volt issue and you had mismatched starter and flywheel/ring gear?
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
He stated it started and made a noise when he shut it off.
It would not even turn over with a 6-12 starter flywheel miss match.
My Blog
