1 members (Lightholder's Dad), 66 guests, and 3 robots.
Topics128,142
Posts1,056,491
Members48,442
Hey guys, I've got a 52 chevy half ton and I would like to upgrade to a double tub master cylinder on the cheap with out a lot of fab work. Any suggestions? Thanks
above all this old truck has taught me patients!
Here's what I used on my '59. No fab work at all, just had to drill a couple holes in frame for brace. Probably would even be fine w/o extra brace. You might see if one is available for your truck.
http://www.ebay.com/itm/Power-brake...arts_Accessories&hash=item35c3b6d356
Im thinking of a double master with out power booster, Im also thinking your 59 is flippin sweet!!!!
TeeRoy is right that 59 is fine. Will my 47 1/2 ton need a power booster? It will have front disks and good rear drums. We are talking 55-60 mph.
Thanks for the compliments guys!
You both will probably be fine with manual dual M/C's.
My truck is 3/4 ton so it already has bigger brakes and the setup I have will just about toss you thru the windshield if you hit the brake pedal hard enough!
Darren
Yea, Im hoping to find a dual master that bolts in the stock location , four seperate lines and just a safer set up that still looks close to stock.
TeeRoy there is one in the LMC book that is duel for $260. It says it is for disk front and drum rears. That is what I need but way over what I was thinking I would have to spend for a master cylinder. You find what you were looking for?
Here's an example of the adapter bracket.
link
Its available from almost every supplier.
You can source the master cylinder from your FLAPS.
I used a 67-69 C10 one.
regards,
Leon
kswillie, Im still looking. I've seen some double masters that look like they might. work at CPP. for a really good price! Leon Thanks for the heads up on the bracket thats the part of the switch that I was most concerned with !
TeeRoy
Here is one from truck and car shop.
http://www.truckandcarshop.com/4759.html
DUAL RESERVOIR MASTER CYLINDERMOUNTING BRACKET KITS
47-09423 47-55 1st. . . . . . . $ 79.00 kit
55-09424 55-59 . . . . . . . . . . .$ 79.00 kit
you can look at their catalog to see the other brake parts
and nice ride hope my 1956 looks that way some day.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
