2 members (delky, Steelonsteel),
235
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I've searched here and looked in my assembly manual,but can't find information. I can't get the latch post and the latch to line up properly.The post jabs against the hole in the latch.Do shims go between the latch panel and the top grill bar?This may help move the hole,to line up better.Thanks Boyd | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I have not seen shims on that assembly, what generally happens is the post where it screws into the upper assembly after years of closing bends the sheet metal. Check and see if it is straight. You want it to open and close without catching because if it hangs up you will be stuck. The latch assembly (lower) has some adjustment when you loosen the 4 attaching bolts. It sounds like it is not that far off. Good luck, test fit first to make sure it latches and unlatches at the first catch before you slam it. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Also check to see that your shoulder bolts on your hood springs and hinges have not backed out. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | | | |
