5 members (59 fleet, Peggy M, Hotrod Lincoln, Cletus1950, tclederman), 157 guests, and 13 robots.
Topics128,106
Posts1,056,217
Members48,436
#914656 01/25/2013 7:46 PM
I've searched here and looked in my assembly manual,but can't find information.
I can't get the latch post and the latch to line up properly.The post jabs against the hole in the latch.Do shims go between the latch panel and the top grill bar?This may help move the hole,to line up better.Thanks
Boyd
I have not seen shims on that assembly, what generally happens is the post where it screws into the upper assembly after years of closing bends the sheet metal. Check and see if it is straight. You want it to open and close without catching because if it hangs up you will be stuck. The latch assembly (lower) has some adjustment when you loosen the 4 attaching bolts. It sounds like it is not that far off. Good luck, test fit first to make sure it latches and unlatches at the first catch before you slam it.
Also check to see that your shoulder bolts on your hood springs and hinges have not backed out.
thankyou
