Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (MNSmith, dt235sd, J Lucas, Hotrod Lincoln), 199 guests, and 6 robots.
Topics128,288
Posts1,058,579
Members48,492
Kinda new over here, I fequent the HAMB and was told about this site.
I recently sold a 52 Chevy two door and would like to get a 47-53 Chevy truck project.
I see quite a a few grain trucks, large 1.5 tonn advertised that look really solid for cheap However, I want to build a 1/2 truck.
Questions: What are the sheet metal differance between the 1/2 ton and larger trucks?
Are the cabs interchangable?
Fenders look different in pictures, the larger trucks appear to have a larger wheel opening.
HUSSEY
I believe cabs are all the same but 1.5T and up have a larger hood, fenders and grill.
the wheel openings are much larger on the big trucks
Cabs are all the same. Usually with the bigger truck you will have some additional parts on the firewall for the hydro-vac and 2-speed rear end if so equipped. It is all easily removed for a 1/2-ton application. The large truck cabs can be a good option sometimes, often they are lower mileage than the small trucks and rust issues may not be as severe in the floors/cowl area. The also offer an easy upgrade to a 5-window if you like that look. Other things to look for which I have found common on the large trucks, upgraded Air-Flow heater, deluxe cab stainless trim, and often uncut dashboards Because PO had not tried to fit in aftermarket radios. Here is a good example this is a 1950 2-ton I paid $150 for a couple years ago. I stripped it in place and the owner scrapped all the rest for another $200.
http://www.flickr.com/photos/advance-design_parts_co/8130558268/in/set-72157631870734114
