9 members (TUTS 59, cmayna, Rusty Heaps, 49choptop, treegrower, Wickedbass, UtahYork, Gray_Ghost, tclederman), 106 guests, and 1 robot.
Topics128,067
Posts1,055,877
Members48,428
#91418 02/03/2004 11:40 PM
I have a 3-spd OD with a toggle switch in place of a governor. It works great! With the switch in the off position the transmission is in OD. With it in the on position the OD is not functional just like it would be with a governor. Correct?
How to wire for a light to let me know when it is engaged? A friend suggested a relay. Anybody with an explanation, schematic, etc.? I am for sure not an electrical guru, but am definitely old and forgetful and need all the help I can get to remember to hit the switch.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
#91419 02/04/2004 1:18 AM
just put a small light [like the high beam one] on the switch too so the whole time the switch is on, the light is on - relays not needed, nor gurus, just hafta remember what the hell that little light is for grin
#91420 02/04/2004 1:24 AM
My trans is wired a little differently than yours. When I have the solenoid activated for OD, the switch is on. I did just as Squeeze suggests, I found a neat looking 12v indicator light that I wired to the switch. When the switch is on & power is applied to the solenoid, the the light illuminates.
#91421 02/17/2004 3:29 AM
I too have an overdrive in my 62 Chevy truck-with the toggle switch hookup. Used a switch that lights up when the od is engaged. My problem is the speedometer doesn't work now. The cable is o.k. so where do I go from here? I have a tach on it do I just estimate my speed with it? Hate to pull the trans as that sucker is heavy!!
Green Machine
#91422 02/17/2004 4:16 AM
Edabbs - if the inner piece of the cable isn't broke, the next step is to drive w/ it disconnected and see [feel] if it turns - more likely to be a bad speedo than a bad trans gear I think
