2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | I have a single terminal 6 volt horn. I assume that the terminal connects to the plus Battery and the horn frame is mounted to a boss on the engine manifold which is ground. where does the single wire from the horn connect. When you press the horn button, this wire get connected to ground? I think? Some enlightenment would be appreciated | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | you need a 3-terminal relay that closes when the horn button grounds, thus and sending +6V to your horn. they are available from numerous old car/truck parts suppliers | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If you have a single horn you don't need a relay but it won't hurt to put one on if you really want to. You don't say what year your truck is???? You can find wiring diagrams here.
| | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | My truck is a 1936 1/2 T but the horn is not Original. Inside the horn is a coil connected to one side of a closed contact. the other side of the contact connects to the case which is ground. If I power the horn, plus to the Horn terminal, and the case is ground, then the coil is energized and the contact opens. Now, if I connect the lead from the horn button to the horn terminal, when i press the button it should connect the ground side energize the coil and the contact should close. Whats wrong with this picture? Is this how the horn works? Wiring Diagrams do not show this. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Your horn button is the ground in the stock configuration. It's not powered. Someone with more knowledge of your type of set up than me will have to chime in but if it were me I'd run a separate hot wire to a separate switch to power the horn or use a stock horn. They are plentiful and relatively cheap on ebay.
| | | | | Joined: Jul 2007 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 37 | I have decided to use a relay. That way I have power in and out with the horn button switching the ground. Thanks
charlie | | |
