7 members (Gdads51, Lightholder's Dad, ShopRag, Hotrod Lincoln, sudsyz, Chip O, 1 invisible),
77
0
Mod | | | Forums66 Topics128,210 Posts1,057,456 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | While installing a new light switch in my 58 Suburban I noticed a small fuse on the back of the switch. I'm curious what that does. Do all the lights stop working if that fuse blows.
It got me thinking that accept for the inline fuse that came with my aftermarket TACH I don't remember seeing any fuses anywhere on the truck. I can't find a fuse panel anywhere. I don't see anything on the wiring diagram either.
Is a fuse panel/block hidden somewhere on the truck? How did they keep the trucks from burning to the ground??
Larry
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | My 58 GMC had a connection block for the bed lights under the cab floor but no fuse block.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the small fuse on the light switch is for the dash and tail lights only [3amp], the springy thermal breakers on the sides of the switch are the headlight overloads, automatically resetting when they cool down, can cause the headlights to go off/on repeatedly if a problem develops, but keep you from totally losing lights .... the only other protection was a fuse panel like this that was only installed when some electrical accessory was ordered, particularly a radio or extra lights .... the fuse block is shown in dotted lines on the wiring diagram labeled ACC JCT BLOCK Bill | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Bill;
Is that inside a black box mounted on the firewall next to the horn relay and voltage regulator? I was wondering what that was. Never thought to see if the cover came off.
My Burb came with a radio and a heater so that may be it.
Larry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no, the fuse panel mounts inside the firewall above the clurch pedal, there's a 'cutout' marked there in the cardboard insulator - shown here from heater installation instructions .... no idea what the box is you have, maybe a picture would figure it Bill | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Bill;
Ok. I'll have to stand on my head and see if I can see anything under there.
Larry
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | easy to see from standing beside the truck and leaning in the door, they considered you might want to change a fuse now n then  Bill | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Bill;
You take all the fun out of this! :-)
Larry
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | My '59 3600 has no fuse panel, only fuse is the one on headlight switch. Of course, it's a bare bones truck, no radio, vacuum wipers, so my lights are the only thing that needs protected. Darren | | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | I checked again on the fuse block. There isn't one anywhere under the dash. Turns out the black box on the firewall is the voltage regulator. Duh!!
My truck has a radio and a heater. I would have thought there would be a fuse box.
Anyway, I plan on buying a complete "new" wiring harness this spring. That will come with a complete fuse panel.
Larry
