| | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I installed my 4 speed transmission, new u-joint and the rebuilt torque tube in my "52" 1/2 ton. I filled the u-joint housing with gear oil but it never reached the fill port. I put in two 32oz bottles and quit. When I went to fill the transmission it did not take much more. Can I assume the gear oil flows into both the u-joint housing and the tranny. I could not find this answer anywhere in the shop manual. I did install a new okie bushing in the torque tube so fluid should not have leaked into the tube.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The rear bearing on the output shaft is not a sealed bearing Bart. So the two spaces are common to each other. Just make sure to check the trans fluid level a few times after driving it a bit. As Tim points out, they will level out eventualy.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | | | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I did install locking clips on the bolts. Whoever had the truck before me did not which is more then likely why my yoke was in the shape it was in. I had to purchase a new yoke. Actually a pair of clips came with the rebuild kit I purchased from Patricks even though a new u-joint did not so I figured it must be pretty important.
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | At least you caught her be for she exploded in the Ball housing. Just in the nick of time. | | | | | Joined: Apr 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 55 | Bart, I realize I am jumping into this a bit late, but where did you find a yoke? I am looking for one for my 56 shortbed stepside and am having a heck of a time locating one.
1956 Apache 1959 Apache 1966 DeVille
| | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I think The Filling Station had new yokes available for around $200. I found a used transmission for $75 that had a good yoke with it.
