Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (MickeyP, baldeagle, Gdads51, Hotrod Lincoln, klhansen, KingG), 56 guests, and 0 robots.
Topics128,007
Posts1,055,281
Members48,418
#913005 01/19/2013 9:30 PM
Hope someone can help ID the engine that's in my 66. It's not the original. I have the Protect-o-plate and from that I can see that the original was a 283 (has code F1009WA). the stamped code on the current engine is S0821XCA. The guy I bought her from said it was a 327 but I'm not sure. Any info would be appreciated.
coker91 #913012 01/19/2013 10:25 PM
The code you have listed doesn't come up on any list I can find. Closest I can find is that it is a Saginaw Service engine, and that it is most likely a '70 or later engine (3 letter suffix code). The closest code that comes up is for a '69 C10-30 350 w/automatic, but that would have a 2 letter suffix code (XC).
Bill Burmeister
coker91 #913026 01/20/2013 12:04 AM
check the casting number on the bellhouse flange driver side, with date codes that might be a better clue
coker91 #913033 01/20/2013 5:42 AM
Thanks. I'll check the casting number as red58 suggests. Can't do it today but probably tomorrow. I'll let you know what I find. Is there an online resource to cross check these numbers? Does GM have something like that somewhere? I'm new to this.
coker91 #913090 01/20/2013 10:17 AM
small block info - others here can help as well
