| | | Forums66 Topics128,004 Posts1,055,250 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 25 New Guy | | New Guy Joined: Dec 2012 Posts: 25 | Hope someone can help ID the engine that's in my 66. It's not the original. I have the Protect-o-plate and from that I can see that the original was a 283 (has code F1009WA). the stamped code on the current engine is S0821XCA. The guy I bought her from said it was a 327 but I'm not sure. Any info would be appreciated. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The code you have listed doesn't come up on any list I can find. Closest I can find is that it is a Saginaw Service engine, and that it is most likely a '70 or later engine (3 letter suffix code). The closest code that comes up is for a '69 C10-30 350 w/automatic, but that would have a 2 letter suffix code (XC).
Bill Burmeister | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | check the casting number on the bellhouse flange driver side, with date codes that might be a better clue
Bill | | | | | Joined: Dec 2012 Posts: 25 New Guy | | New Guy Joined: Dec 2012 Posts: 25 | Thanks. I'll check the casting number as red58 suggests. Can't do it today but probably tomorrow. I'll let you know what I find. Is there an online resource to cross check these numbers? Does GM have something like that somewhere? I'm new to this. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | small block info - others here can help as well Bill | | |
