| | | Forums66 Topics128,088 Posts1,056,414 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 50 | Can a 6v gas gage be repair,must have some type of resister in it.If not can you buy gage, an use old face plate,seen all new gage have face plate | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I'm not sure if you are asking a question or stating that it can be done. I know that I was able to repair my gauge, it was fried and I replaced the fine resistor wire and now it works fine. | | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | Jim Carters repairs them. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Leo, could you fill us in a little more on what you did to repair your gauge? Did you take any pictures? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Leo, could you fill us in a little more on what you did to repair your gauge? Did you take any pictures? Denny Graham Sandwich, IL The gas gauge has two very fine copper wires, about as thick as a 5 amp fuse. One was fried and I simply soldered another one in place. The replacement wire was a single strand of a copper braided wire. | | | | | Joined: Apr 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 50 | | | |
