4 members (1955 1 Series, baldeagle, Shaffer's1950, 1 invisible), 89 guests, and 2 robots.
Topics128,015
Posts1,055,335
Members48,419
#909723 01/08/2013 10:13 AM
Hi there..
A friend of mine went out to check an engine for me, which is for sale..
The block casting # is: 3851659 (I think it's a 292)
What do you get out of this?
Then it has some other numbers that I can't find out what means:
CON 2 and J 2 5
Does these numbers help identify the age and type of engine?
On the engine head: 4888 F 28
If this is a 292 how do I find out the age and if it's a long or a short model?
Have tried to use the list of casting numbers, but it does'nt help me a lot - Hope for a little help here thumbs_up
Thanks a lot!
Thank you!
Kaad
Kaad
Not sure on the casting #s but a dead giveaway on a 292 is that the motor mount bolt bosses are not directly opposite each other as on all the other L6 engines.
They are staggered,as in the passenger side mount location is another 5/6 inches foward than the drivers side and the fuel pump is located behind,or to the rear of the motor mount.
Also the push rod/lifter covers are about 2 inches taller.
Hope this helps.
regards,
steve sr.
CON 2 refers to Conveyor 2 at the engine plant and J (Oct) 2 (2nd) 5 (1965). As far as I know all 292 are tall deck engines meaning that they have blocks that are taller by about 1-3/4" than a 230-250 which are the same block but use different strokes. Your block number was cast from 63'-66'.
This is my understanding of these engines.
The number on your head likely is from being a replacement head.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Thanks a lot..
But how do you see its from the period 63'-66'?
When i look it up I just find that the engine is from 63' - 76'..
I get the date code now, but the "5" could be 75' or am I wrong??
Thanks again!
Thank you!
Kaad
The casting number you claim identifies it as having been made as stated. Other years used different casting numbers.
Dave
Casting # 3851659 is listed as a 292 from 1963-66
and had 7/16" Bolt Holes in Crankshaft Flange.
Starting in 1967, casting # 3851659
had 1/2" Bolt Holes in Crankshaft Flange.
-Tom
1950 Chevy 3100 w/ 1956 235
I'm sorry, but I have to ask again.. The casting # you refer to are the same..
This is what I find when I look it up:
3851659 Chevrolet 63-76 292
So I do understand it's possible it is from '63-'66, but what I don't understand is how you guys know/say it's not a newer model.. from for example '66-'76
Thanks a lot it is a big help you give!
Thank you!
Kaad
my book says 1963-1972 truck
1951 3100 Chevrolet
Check the engine code stamped into a ledge by the distributor. An example would be F1010UT. This source says a 292 65' engine should end in a UT or UH suffix. http://no25.chuckthetruck.com/page3.html
Sorry, no 292 info listed for a 75' engine in the above source.
Hope this helps.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
